i'm trying to perform Multi Body Simulation using Hypermesh because there is a Problem with Motionview.
This model consist of 9 moving components. i have set all the boundaries, Motion, gravity, contacts, joints and everything (as far as im aware). i have followed the guides from OS-1940. When i try to run the calculation, this error showed up.
verspru joints.out
Hi yehoo
I can see from the .OUT file, that the gravity has zero value. Please update it
Also, the shell elements are not assigned with PSHELL property. Check and ensure whether all the shell elements (quad4) are assigned with a PSHELL property.
If the error still persists, please share the model file.
You can use the secure transfer link if needed.
https://ftin.india.altair.com:8443/filedrop/~Ma3TaE
yehoo likes this
