Sign in to follow this
NGUYEN Thi Kim Ngan
Field source coupling CST simulation
Hi everyone!
Have anybody ever used Field Source coupling in CST.
I would like to simulate a finite Frequency Selective Surface (FSS) using field source coupling of Circuit and System tool.
 I setup my simulation as experiment in anechoic chamber (2 standard horn antenna as transmitted and recieved source with finite FSS in the middle). But my work encountered an error in exporting the S parameters result and sometimes getting memory problem. Could you please help me to find out where is mistake and the way to fix it.
Actually, I found the field source coupling document tutorial of CST version 2015 . I followed the workflow which this document proposed.
I would like to thank you for your help!
Have a good day!
Best and regard,
document_tutorial_of_CST_version_2015.pdf
