narasimhamurthy
INTERNAL PROGRAMMING ERROR
i am performing buckling analysis but getting error as show in below.
*** INTERNAL PROGRAMMING ERROR ***
   in file "xdsemx_i8.F", at location # 262.
       ioerr(1) =          1
 ****  ABORTING RUN DUE TO AN INTERNAL ERROR  ****
i am using Optisrtuct 2018 version
how to solve this error?
Thanks and Regards,
Narasimhamurthy
M-NG-FR-end.out
Can you give a final try by unchecking output request or param cards defined.In the past we have seen this programming error is mainly observed because of output request /param.
On ‎5‎/‎31‎/‎2019 at 6:57 PM, narasimhamurthy said:
removed all PARAM and output request.
but error not yet solved.
Last shared files are based on 2017.2.So I am commenting based on the files shared in this quote using 2018.0.1
This is related to some IO issue during a matrix vector multiplication in Lanczos. I am afraid I will need the model to see what could be the problem but as a workaround you could try using MUMPS as the lanczos solver via the solvtype card and see if it works out. Alternatively you could try ddm mode (even with 1 proc).
