Dear friends,
Good morning, I am solving a modelo and when I run it I have this message:
*** ERROR # 153 ***
 Exactly zero pivoting encountered during Numerical Factorization;
 the model may have rigid body mode.
  Solver error no. =   -514
        spc set id = 1
             index =      1
 Possible reasons are:
 1) insufficiently constrained model,
 2) having rigid body mechanisms within the model,
 3) extremely ill-conditioned rigid element sets,
 4) extremely thin shells (as used for skinning) that have MID2/MID3,
 5) gap elements with extremely high stiffness (KA, especially KT or MU).
 6) extremely high Poisson's ratio in hyperelasticity material definition.
 Check the model and rerun the problem.
 (MECHCHECK may be used to find the rigid body modes.  To do so,
  change the input to be an eigenvalue analysis and add MECHCHECK.)
 (WARNING: results obtained with MECHCHECK cannot be used because
          the model is changed internally.) This error was detected in subroutine bcsmtxfct.
I can't find the way to define the MECHCHECK option (anybody could please share a detailed tutorial of it? Because I define an EIGENVALUE analysis but then I don¿t kno how to define the MECHCHECK option.
Thank you very much for your attention. Best regards.
Dear Rahul,
Thank you very much for your reply, it has been useful to me. I have two more questions: when I run considering that control card, I've got this result:
Iteration Subcase     Variable  Grid/Elem ID   Value
    0      1 MaxDisp                 40574_X  6.5587e+12
What I can understand is that the Element ID 40574 is not constrained. How is it possible to find it? I try to mask it but I can't.
Once that I have defined that Control Card, how I can disable it?
JJJ
Mask element by id:Reverse: Fit to screen: Add nodes on that element: find attached the adjacent element
Disable option is available in the control card section.
