Imanol
Clear Output Command
Is there any command that clears the output window in FLUX?
I want to simulate a parameter sweep with lots of different values for some geometric parameters.
I have a script that sets the values of the parameters at each step, then meshes the geometry, simulates the configuration, exports and deletes the results, deletes the mesh, and repeats the process with new values.
After several configurations are simulated, the application just crashes completely, and it closes the project without any error message. I have to mention that I am not using any command for closing the project in my script, so it should not happen.
As I am not storing the results of the simulation in the RAM memory of my computer, I think that the problem comes when the output window in FLUX displays too many rows.
Is there any command to clear the output window?
Thanks in advance,
Imanol
Hello Imanol,
Unfortunately there is no command to clear the output window. Additionally, all the information that is displayed in this windows is also written in the ".log" project file.
Anyway, I really think its length should not be a problem. More likely there exists another bug which is blocking your project.
For further help, please send me the ".log" and the ".report" files associated with the project execution that crashes.
Best regards.
Imanol likes this
Thank you Alejandro!
I think that the application will have crashed by tomorrow morning, so I will send you the files then. I have executed the sweep again, so they have been overwritten.
BR,
Imanol
