Sirajudheen
Is there any option in feko to import far field radiation pattern E theta and E phi
Hello @Sirajudheen
Have you managed to import the radiation pattern?
The answer above tells you how to import the data to use it as a source in further simulations - see the "Field Data" and "Equivalent Sources" sections in the CADFEKO chapter of the Feko User Guide. If it is not a Feko far field result (.ffe file), you can refer to the AR card documentation for the required format.
You can also import the data into POSTFEKO to plot it on a graph - see the "Data Import" section in the POSTFEKO chapter of the Feko User Guide. If the format is not Feko far field data (.ffe), you can import it as a custom data file.
Kind regards
Madelé
