Sirajudheen
Format error while loading far field radiation pattern from an external data file
Hello @Sirajudheen
For others to be able to assist, it would help if you could explain what you would like to do with the data and what format the data is in.
Are you using CADFEKO to import the radiation pattern to use it as a source in further simulations? If so, please refer to the "AR Card" documentation for the required format.
Kind regards
Madelé
Sirajudheen likes this
