afura
Hypermesh 2017.2 Node picking problem
I have been struggling to pick nodes from the screen, specially when the node I want to pick  is the independent (centre) node of an  RBE (spider) with lots of dependant nodes. This did not use to be a problem in older versions. Do other people have this issue and is there any way around this problem? I have tried to adjust  the "node tol", "pick tol" on the mesh option but it did not help.
Thanks
Hi afura
You can identify the independent node id of a rigid by using card edit option. click on card edit > select the rigid element and set the options as per image > click edit and then you can see the independent node of rigid.
Then for a further selection of this node you can select using node id
