RokHodnik
*** ERROR # 2784 *** Solver failed in the eigen solution of reduced order model, due to the ill-conditioning of the FEA model.
Hello!
I am trying to run an analysis of a solid model based on steps described in ''HowTo_OptiStruct_Flux'' tutorial included in the tutorial install directory. I want to make an vibro-acoustic analysis of an electric motor based on imported forces from Altair Flux. Currently dealing with basics and I want to make analysis on a simple motor from Flux Overlay import. I have assigned mesh, load steps, materials and constraints as in the tutorial, but I got quite a few errors. Some of them I have already managed to solve thx to this forum.
Now I ran into a problem below, that I cannot find a solution online or cannot solve it myself. Full error text in attached file.
 Please check if there is any message about mechanisms printed above,
 make proper fix and rerun with it.
 Some other possible causes and solutions:
 1. Solver may fail due to extreme large upper bound in EIGRL/A card.
        Reduce the upper bound.
 2. Solver may fail due to nearly rigid body modes:
        Set PARAM,RBMEIG to be higher than the eigenvalue of the highest
        rigid body modes.
Thanks for your help.
Best regards,
Rok
ERROR # 2784.txt
