Imanol
Unable to Simulate Parametric Distribution Scenarios
I have been using distributed simulations for the last couple of months, and I have never had any problem, until this week.
First, I was using the 2018.1 version of FLUX, and as I said, it was all working the right way. On monday, however, it stopped working. A simulation started to run without being distributed even though the scenario had the distributed computing box checked.
Just in case, I followed the Distribution Manager Configuration steps again, after deleting all CDE folders from my Temp folder, and as it was still not working, I uninstalled and reinstalled Flux on my computer.
The problem still continued, and I requested the newest version of the software, hoping that it would all be right with this one, but no, the problem still exists. I installed Flux2019.0 and the 2019.0.1 HotFix, and runed the Distribution Manager Configuration. Now when I am trying to simulate, I get the following error:
Job 39 >>java.lang.RuntimeException: java.lang.Exception: Server process failure before reaching initialized status: SocketServerProcess{Id=FLUX2D_2019.0_64_162, Ports=(1101, 1100)}Job not runnable for global reasons: [Requested server type unavailable:   Server types: []   Requested: FLUX2D_2019.0_64]<< Job 39
Job 40 >>java.lang.RuntimeException: java.lang.Exception: Server process failure before reaching initialized status: SocketServerProcess{Id=FLUX2D_2019.0_64_167, Ports=(1111, 1110)}Job not runnable for global reasons: [Requested server type unavailable:   Server types: []   Requested: FLUX2D_2019.0_64]<< Job 40
Job 41 >>java.lang.RuntimeException: java.lang.Exception: Server process failure before reaching initialized status: SocketServerProcess{Id=FLUX2D_2019.0_64_164, Ports=(1105, 1104)}Job not runnable for global reasons: [Requested server type unavailable:   Server types: []   Requested: FLUX2D_2019.0_64]<< Job 41
Job 42 >>java.lang.RuntimeException: java.lang.Exception: Server process failure before reaching initialized status: SocketServerProcess{Id=FLUX2D_2019.0_64_165, Ports=(1107, 1106)}Job not runnable for global reasons: [Requested server type unavailable:   Server types: []   Requested: FLUX2D_2019.0_64]<< Job 42
Job 43 >>java.lang.RuntimeException: java.rmi.ConnectException: Connection refused to host: mgel11308bw012; nested exception is: java.net.ConnectException: Connection refused: connectJob not runnable for global reasons: [Requested server type unavailable:   Server types: []   Requested: FLUX2D_2019.0_64]<< Job 43
Job 44 >>java.lang.RuntimeException: java.rmi.ConnectException: Connection refused to host: mgel11308bw012; nested exception is: java.net.ConnectException: Connection refused: connectJob not runnable for global reasons: [Requested server type unavailable:   Server types: []   Requested: FLUX2D_2019.0_64]<< Job 44
Job 45 >>java.lang.RuntimeException: java.rmi.ConnectException: Connection refused to host: mgel11308bw012; nested exception is: java.net.ConnectException: Connection refused: connectJob not runnable for global reasons: [Requested server type unavailable:   Server types: []   Requested: FLUX2D_2019.0_64]<< Job 45
Job 46 >>java.lang.RuntimeException: java.lang.Exception: Server process failure before reaching initialized status: SocketServerProcess{Id=FLUX2D_2019.0_64_171, Ports=(1119, 1118)}Job not runnable for global reasons: [Requested server type unavailable:   Server types: []   Requested: FLUX2D_2019.0_64]<< Job 46
Job 47 >>java.lang.RuntimeException: java.lang.Exception: Server process failure before reaching initialized status: SocketServerProcess{Id=FLUX2D_2019.0_64_169, Ports=(1115, 1114)}Job not runnable for global reasons: [Requested server type unavailable:   Server types: []   Requested: FLUX2D_2019.0_64]<< Job 47
Job 48 >>java.lang.RuntimeException: java.lang.Exception: Server process failure before reaching initialized status: SocketServerProcess{Id=FLUX2D_2019.0_64_170, Ports=(1117, 1116)}Job not runnable for global reasons: [Requested server type unavailable:   Server types: []   Requested: FLUX2D_2019.0_64]<< Job 48
Job 49 >>java.lang.RuntimeException: java.lang.Exception: Server process failure before reaching initialized status: SocketServerProcess{Id=FLUX2D_2019.0_64_168, Ports=(1113, 1112)}Job not runnable for global reasons: [Requested server type unavailable:   Server types: []   Requested: FLUX2D_2019.0_64]<< Job 49
Job 50 >>java.lang.RuntimeException: java.lang.Exception: Server process failure before reaching initialized status: SocketServerProcess{Id=FLUX2D_2019.0_64_172, Ports=(1121, 1120)}Job not runnable for global reasons: [Requested server type unavailable:   Server types: []   Requested: FLUX2D_2019.0_64]<< Job 50
Job 51 >>java.lang.RuntimeException: java.lang.Exception: Server process failure before reaching initialized status: SocketServerProcess{Id=FLUX2D_2019.0_64_173, Ports=(1123, 1122)}Job not runnable for global reasons: [Requested server type unavailable:   Server types: []   Requested: FLUX2D_2019.0_64]<< Job 51
The error was the same with the previous version, is there a solution for my issue?
Do you have any idea about what I may be making wrong?
Best regards,
Imanol
