Juan David de la Fuente 0 Report post Posted June 14 Hello. I've been struggling with the simulation of a sensor consisting of a coil with a ferromagnetic core and a magnet. The main output to analyse is the voltage induced on the coil by a rotating target. I'm modeling the coil as stranded-coil conductor coupled with a series resistor (see attached circuit.png). When measuring the voltage across the coil, I'm looking at very high fluctuations in voltage (see attached results.png), if I take the derivative of the flux (flux.png) through the coil, the behavior is minimized a bit, but still present. Any ideas to improve this high variation? Thanks. Quote Share this post Link to post Share on other sites
Abdessamed 21 Report post Posted June 17 Hi, Can you send me you Flux project (zip format without results). Best regards. Quote Share this post Link to post Share on other sites
Juan David de la Fuente 0 Report post Posted June 17 2 hours ago, Abdessamed said: Hi, Can you send me you Flux project (zip format without results). Best regards. Hi, Thanks for your response. This is a company project, unfortunately I'm not able to share any confidential information unless you are an Altair member. If that is your case, could you please share your email? Regards. Quote Share this post Link to post Share on other sites
Abdessamed 21 Report post Posted June 19 Hi, You can contact the support: Flux_Support_Apac@altair.com Thank and best regards. Quote Share this post Link to post Share on other sites
