jix218
EW-BATCH Failed
Hi, I am using Inspire Extrude 2019.1 to run extrusion simulation. I created a die file in Solidworks, and have defined each parameter in Altair. When I run the simulation, it always stopped after 10 or 20 seconds with a error message showing 'no GRF file in the project folder' and 'EW-Batch failed' in the description after 'completing requirement' message. I have run the tutorial successfully so there is nothing wrong with the software. And I followed the same steps for my file. It seems that it fails when loading my file. Anyone knows what to do?? Please help. Thanks!
D.iep
Hi, I renamed each part in my file with Plate, Land, and Profile. Now it can go to meshing stage but the software stuck at this stage with 'Starting 3D polymer mesh' message. Anyone knows what might cause this?
Hi Duc
You have to cut your file into different sections. Like Plate, Land, Profile for Inspire to run. Also, make sure you orient you part in the right direction. Polymer should be flow in the Z direction. Also avoid any wired name for your file. This should solve your problem.
