RoKet
Re-use / multiple use of model
Hi all,
I have a model of a controlled drive unit with inputs and outputs. Now I want to use this unit several times in another model of a more complex machine, the main parameters (power, max. speed, max. displacement) should be the same in all instances of the unit. Furthermore, modifications should have effect on all units.
What I have in mind are two solutions: Supermodel of unit, that may be stored in a library (no common update of model possible), or an 'Include Diagram' construct.
What I haven't said yet: the interface ports of my drive unit should be Activate signal ports and Modelica ports :) . Is this a killer criterion?
Thanks for your ideas!
Ronald
Ciao Rocket,
modifications should have effect on all units => you create a library with your basic units.
When you do so, if you change anything in the library, this will affect all the models which are using that library => you get what you want (if I've well understood).
Supermodel of unit, that may be stored in a library (no common update of model possible): you are probably speaking about superblocks here, if you mask them then they can be placed into a library. Common update is possible in libraries. It is not possible when you create a Palette which is slightly different.
the interface ports of my drive unit should be Activate signal ports and Modelica ports: no problem for this
I would use a library rather than an include diagram.
Liv
Liv and Chris,
You are my gods :)! Thank you for putting me on the right track.
One questions is still left: if I use the library approach, do I have to deliver my model with the library to a customer?
Ronald
