Joel Rodarte
Elemental System, Global System, Analysis System
Hello Everyone,
I would like to know what is the difference between Elemental System, Global System, Analysis System.
I am interested in this since hypermesh allows to extract (strains,stress,element forces etc) from each of these systems. I regularly use the one that is by default "Element system" but I want to understand what is the difference between them and what can I obtain different of each of them.
Thank you for your time! :)
Elemental System = private system of each element (see in reference help of CBEAM, CTRIA, CQUAD card)
Analysis system = as solver output.
Global system (you saw it, I am sure)
principle values are independent to systems.
Thank you for your help!
I was not so wrong then. However i am extracting forces from beams in the matrix browser and when I use Analysisi system to retrieve information I do get information about the magnitude and comonents in them; when I use Elemental System I obtain the magnitude but not the components x and y  (N/A). Do you know why this might happen?
Green is by analysis system.
Thank you.
I don't know.
But use analysis sysyem is better, because that is solver output.
by other system, values are calculated from solver output (so errors may happen)
