Soichiro Fukamachi
What can I do for "`FMIConnector:-CreateArchive`. Error: "
I faced `FMIConnector:-CreateArchive`. Error:   when simulating Activate model with Modelica blocks.
What can I do for this?
---- detail ----
I ran "C:\Program Files\Altair\2019\ActivateBasic2019.1\tutorial_models\Extended_Book_Models\Chapter_11_Physical_modeling\motor.scm" ,
then I found error messages as below:
Quote
Starting Simulation
Error: Error, (in FMIConnector:-GenerateCode) procedure: `FMIConnector:-GenerateCode`. Error:
procedure: `FMIConnector:-CreateArchive`. Error:
shared library (.so/.dll file) was not successfully generated. Check the errors by manually executing .bat file
( 99 )
Block(s): DC Motor /EMF FromModelica DC Motor /Inertia_1 Ground_2 DC Motor/Resistor_1 DC Motor/EMF ToModelica DC Motor/Inertia_1 FromModelica_2 FromModelica_1 DC Motor /Resistor_1 Ground_2_1 Torque_1 DC Motor/Inductor_1 VoltageSensor_1 DC Motor /Inductor_1 SpeedSensor_1 AngleSensor_1 StepVoltage_1
Model: motor
with Windows10 64bit, Activate 2019.1.
I found that, "tools>compile" command shows almost same messages like this:
Quote
Starting Compilation
( 99 )
Model: motor
And, I created new Activate model includes modelica blocks and ran, then almost same Errors appeared.
That's a matter around C++ compilers?
I'm working with Visual Studio 2017 Express, and
Quote
> vssGetCompilerName()
ans = vc_env
seems OK.
Regards.
Hi Soichiro Fukamachi,
It seems that you haven't installed the right compiler. vc_enc isn't a C++-compiler. The answer to getCompilerName should be like this:
ans = vc15_community_x64
Please check that you have installed the C++-compiler of the package (another tick of a check box during installation). C:\Program Files (x86)\Microsoft Visual Studio 17.0\VC (or similar) should contain vcvarsall.bat and \bin\amd64\cl.exe.
Hi, RoKet.
It goes  all right.
I removed Visual Studio 2017 Express, then installed Visual Studio Build Tools 2017.
So that:
Quote
> vssGetCompilerName
ans = vc15_buildtools
Finally, the simulation runs successfully!
Thank you for your advice.
I get the same error as described above, however I also get this:
Quote
> vssGetCompilerName
My paths looks like this:
Do you know what might be wrong in my setup?
Looking forward to your reply, thanks in advance!
Romain
Hi Romain B,
I have no experience with Visual Studio Build Tools 2017, I always use Visual Studio Community (https://visualstudio.microsoft.com/downloads/). It is important to install the C++ environment (sorry for German version)
Settings in Activate doesn't matter, the compiler is searched automatically (and hopefully found).
Adriano,
The first time that I've tried to Run a modelica tutorial model, I got the same problem as you, even showing: ans = vc15_buildtools (So theorically I've installed the C++ package).
What I've done was to check what I've indeed installed on C++ package as mentioned by @RoKet (once has a wide options to select).
I'd suggest you to do the same thing. So when you open the "vs_BuildTools", please do check these items that I've indicated with a red arrow (picture below, sorry for the portuguese), and then modify your installation to install then.
 One check that you can do is, searching for a similar path below (as mentioned by @RoKet): (It is curious that before doing these changes, I did not have these folders, even with C++ package installed).
 path.thumb.png.b4ad29fc1615f2a8346e0d10903a64d5.pngvs_BuildTools.zip
Maybe with this, you can run your model (it worked exactly like that with me). By the way, I've attached the vs_BuildTools to you modify you package.
João.
