HI,
by using tcl script i am trying to put a washer split  at different location with certain offset value depending on the diameter of the hole . The edge id gets changed after i perform a washer split operation, hence i could not able to perform next washer split operation, due older edge id does not exist any more
Any type of editing on surfaces will result in change of id's
I had the same problem, at that time i created metadata and proceeded with that info instead of following edge id's.
You can try using the following api's  *metadatamarkremove, *metadatamarkstring and hm_metadata
what is metadata I have seen some APIs available but not sure how to use'em.
It would be really helpful if you can share any sample scripts for understanding the concept.
Thanks in advance.
Brahmadev.
