Hello, I want to simulate the following mechanism
I need the orange pin to slide trhough  the green slot when the green slot moves due to other machanism movement.
This is the configuration of contact that I used: Nodes on the all arround the slot are the slave and all of the pin elements (membrane of a 3D) is the master.
And the results are these:
what do you suggest i can do? What is wrong with my contact card, or what other approach do you suggest?
thank you for your itme.
