Damian Medrykowski
Lack of mrf file after nominal run evaluation
Hello there,
I have a problem with running a Study (I've tried on Tutorial file and also on my own model).
After evaluation of Nominal run there is no .mrf file created in approach run folder, therefore I'm not able to set the proper response
(I'm not able to choose the file for Data Sources).
In MotionView analysis output options T've marked to create mrf file, and after MotionView Analysis there is such file created.
But unfortunately after HyperStudy nomial run there are just some other files but not the important one :(
Thank you in advance
Does it give any error in the message log of HyperStudy?If so please share the screenshot of same.
Which tutorial & which version of HyperStudy you sre using?
Hi Damian,
I follow up on this request. Do you still encounter the issue to get *.mrf files written in the run folders?
If yes, can you please look at the task_execute_stderr.txt and task_execute_stdout.txt files, which are available in the run folders. Can you please check if there are any errors recovered from MotionSolve execution? It can explain why *.mrf files are not written.
I suggest you also to try the tutorial HS-1030, which is available in the HyperStudy help. It's another example with MotionSolve. Can you please check if the behavior is the same with this model?
Kind regards,
Diana
