Mrt
using nonlinear subcase for linear buckling
Hello all!
i have one question!
is it possible in Optstrct to do these thing?
i want to use nonlinear analysis (preload by weight) for linear buckling analysis/
any idea?
thank a lot, Guys!
it is possible to use nonlinear quasistatic analysis as a preload for linear buckling analysis (see attached model). From Optistruct help:
Quote
A linear buckling solution cannot be performed on a linear static subcase that uses inertia relief. STATSUB(BUCKLING) can only be used to reference buckling to linear static or nonlinear static (small displacement + N2S/S2S contact only) subcases. For more information in using a preloaded linear static analysis (with STATSUB(PRELOAD) pointing to large displacement nonlinear analysis), in buckling analysis, refer to Linear Buckling Analysis in the User Guide.
NLASTAT+BUCKLING.hm
Mrt and Rahul R like this
