Novice_Tcl_Scripter
Hyperview - Use component/model color for no results
There is no available api
But by dumping the check box, I see its state variable is:
::post::optionsdialog::usepcolor
you can set it equal true to turn on and false to turn off the check box
after set it, you must call:
::post::optionsdialog::OnButtonPressed 0
because actual state variable is hidden and if you don't call that proc, it will restore the above variable!
(this is called as you click "Apply")
Livil Lyle likes this
