wimarti22
Exporting Geometry in Inspire Form
I am currently working on a project in Inspire Form and need to use the geometry of the sheet metal that I press in a "tryout" of a crash form and springback. When I select "save as" it exports the geometry of the die and the sheet metal before the press rather than after. How do I get the final sheet metal geometry?
hi,
You can open your run history folder then find the file with extension *.sta.
That file is the mesh of the blank after deformed.
Once you have the mesh, you can use hypermesh to recreate the surface.
