Sunilshanmugam
SPOT WELD, ADHESIVE & P13SPRING Material properties
Greetings all,
I am doing Vehicle Frontal Crash simulation.
I have below mentioned queries while using some default cards, material and properties in radioss.
HEXA SPOT WELD- P43_CONNECT-M59_CONNECT (Default)
HEXA ADHESIVE- P43_CONNECT-M59_CONNECT (Default)
Since i dont have exact material information for SPOT and Adhesive is it advisable using this default values and curves.
If i try using MAT1 instead of M59 there is part, mat incompatible error popping out since those wont obey the material law.
Please advise with better solution.
