I'd like to analyze harmonic response with fluid grid.
I set PAABSF as non reflect boundary condition.
but these elements occurred errors.
 What is the problem?
I guess you have solid elements in your model and while meshing you would have used shell element (CTRIA) for solid element (Ctetra)creation.Please delete CTRIA elements and run again.
Delete:Element by config:CTRIA3:select entity and delete
But CTRIA3 is used in PAABSF and input Panel,(boundary condition)
So I cannot delete CTRIA3.
How should I do?
I understand that we cannot change element type from card edit.
we need to set from 2D⇒elem types panel.
I could clear the element problem,
but another error occurred...
Could you find the cause?
