Sign in to follow this
tejas6
ERROR # 4965 & ERROR 5905
Hi @tejas6
group1 & 2 should be changed from stick to freeze contact.
Self contact for the spring can be set-up with S2S and CONSLI. However, the model fails to converge beyond 75% with errors:
*** ERROR # 4965 ***
 Maximum number of time increment cutbacks reached,
 analysis aborted.
 *** ERROR # 5905 ***
 Severe element distortion detected,
 analysis aborted.
Because the model undergoes geometric and contact nonlinearities it could be solved more computationally efficient with Radioss explicit solver.
hm_edit.fem hm_edit.hm
If the solver reports excessive mesh distortion, consider the following reasons:
  • Excessive or unrealistic loading
  • Over-constrained FE model
  • Inconsistent unit system between model, material and/or loading that lead to excessive deformation
Reviewing the last non-converged iteration in HyperView will help
Please refer to attached model from OptiStruct example guide.
OS-E 0195 Compression of Helical Springs usingSelf-Contact.pdf mola_Self_contact_v2_SPCF.fem
Simon Križnik likes this
