Hey there,
I've a question about the global origin in motionview. How can I upload a model by assembly wizard and set the origin?
For example, I need the global origin in the same point of the centre of the wheel in a double whisbone suspension model.
Thanks for the help!
Hi Tetoldini,
One easy way to do it is using the System translation inside MotionView.
You can select the master model system and all the other systems will follow it.
Be careful with the Y axis since the assembly wizard models are parametrized in left and right side.
Best regards,
Felipe.
Chris Coker likes this
Sign in to follow this
