Pandurang 18 Report post Posted July 9 HI All, i want to write script to project the face nodes on nearest surface.. is there any API? any idea how to do this.. @tinh Thanks Quote Share this post Link to post Share on other sites
tinh 739 Report post Posted July 19 Hi the script is thought about long time ago There are some ways but not actually efficient. First i toggle all green lines to form 1 surf only => project easily, don't need script But sometimes mess up the mesh! Then i loop with each surf to project nodes on them. Mesh is not mess up But script very slow because large number of small surfs Then loop with each node to find closest surface, faster as surf list as shorter (appliable because we can limit surfs in a comp) A script like this Createmark surfs 1 all (or $slist , example: surfs in a comp => faster) Foreach node $nlist ( Createmark node 1 $node Lassign [hm_measureshortestdistance surfs 1 0 0 nodes 1 0 0] => closestSurf x y z Nodemodify $node $x $y $z ) Then i .... am thinking other ways because above one still too long (so usually, i let it run finally, overnight. Tips: If you can divide a big model file to many files, each file has a few comps, above script will run much faster. And by dividing model you can run files on hm sessions simultenously. Pandurang likes this Quote Share this post Link to post Share on other sites
Pandurang 18 Report post Posted July 19 I wrote this one...this also takes lot of time... @tinh Quote Share this post Link to post Share on other sites
tinh 739 Report post Posted July 19 1.Don't *createmark surfs 1 displayed every loop ! 2.Use *nodemodify is faster than *projectmark 3.Ignore associated nodes *createmark elems 1 displayed *findfaces elems 1 *createmark nodes 1 "by comp name" ^faces *createmark surfs 1 displayed *createmark nodes 2 "by surface on mark" 1 *markdifference nodes 1 nodes 2 set nd_list ... => i think much faster Pandurang likes this Quote Share this post Link to post Share on other sites
Pandurang 18 Report post Posted July 19 Thanks This will be much better.. Quote Share this post Link to post Share on other sites
