Sign in to follow this
nehasharma
How to stop Graphics update in HyperView
How can I stop HyperView graphics to get updated while running a script.
Since to capture images there is lot of mask, unmask and draw operations while the script is running.
It seems to be flickering in HV window. Is there any way to stop graphics update in HV however it should capture images as well.
Thank you
Neha
Check the "block redraw"command. I'm not sure about the exact command name but those words appear in the command. For images just type "image" in the search option in hypermesh reference guide. I'll gt back if I get the exact command names.
@nehasharma
use the following:
hm_blockredraw 1      #stops graphic window from refreshing
hm_blockredraw 0      #resume graphics window update
You can do the same thing from Preferences > Script performance
Blocking redraw can help optimize code runtime!
