Joel Rodarte
Difference betwen Stick, Freez and Tie contacts?
TYPE = SLIDE
  • Only valid for small sliding
  • Only normal contact stiffness is generated
TYPE = STICK
  • No sliding once gap is closed
TYPE = FREEZE
  • Enforces zero relative motion between contact surfaces
  • Contacts are closed at all times, no matter the distance between them
  • Rotations on the slave patch are matched to the rotations of the master patch (LGDISP)
