Siva7279
TCL Script_To load many input and output files in a folder
     Kindly help to make the macro which is used to load the many input and output files in a folderin hyperview and to atomatically apply the desired result.
For ex: The nastran deck is same but the load is applied at different locations. So i need a tcl macro which will call the input (.dat or .inp )and output (.op2 or .odb) in the order wise in Hyperview and apply the desired outputs.  Instead of calling all the files separately , it will be easy if done through macro.
