uri
1. Mesh problem 2.Niyama interpetation
ICAST Version 2019.2
For the attached Aluminum casting file: Mesh=5mm Temp=765C Fill-time 14sec Material AL A356
1.When making the Mold 6-8 mm below top (as in reality), mesh fails.
2. When checking for Niyama (0.3) the all partis colored. Is it going to be bad part?
Please advise
9643-1101-10CDt-PART_1.icast
Hi Uri,
Can you please check the case definition. The riser cannot be outside the mold, how can you hold the melt ? It has to be either a sleeve or mold for the melt to hold
Santhanu
1. When I make the Mold top height the same as the risers, (As in reality) the mesh fails.
If I make the mold higher than the risers I miss the air cooling effect because of mold isolation.
Please check and advise.
2.  What about an answer regarding the Niyama problem?
