RokHodnik
Sinusoidally distributed forces
Hello!
I would like to apply forces in the inside of an toroid body. I find command to apply constant amplitude forces. But I would like to apply forces that have amplitude depending on the angle and their dependence is sinusoidal.
For better understanding I am attaching the figure below.
Thanks for your help.
the option you are looking for should be found in one of the following:
- Analysis/Loads/Bearing Pressure (works only if the surface is a cylinder or a partial cylinder, it looks so in the pic)
- Loads/Create Force /as function of XYZ (but this may request some more clicks).
