Sudhanshu Kashyap
Motorcycle Motion View Model - for Load Calculation
Hi Everyone,
I am in the process of making a motorcycle model in motion view and wanted to get the forces on each components under several Loading cases.
I am interested in finding the forces under vertical bump condition on front and rear wheels.
But, I am facing some problems in generating the results. As, the system has been run but still no results were generated.
Can anyone help me in this. I am uploading <.mdl>file.
Chassis(Frame)_graphic.h3d
Frame with Points.mdl
16 minutes ago, Sudhanshu Kashyap said:
Hi Everyone,
I have imported the frame as cad file , not .fem file.
Your frame graphic h3d is a graphic, not a flexbody.  I would recommended initially running the model without a flexbody, to get things fully debugged.  Then, create the flexbody and add it to the model.
So, in short, uncheck the FlexBody (CMS) feature until you get a proper flexbody created to use with the model.
Chris
Another quick observation on your model.
The mass and inertia values of your model are all "zero".  You will not get a valid solution to the basic equation F=m*a if all your "m" are zero.
Kind regards,
Chris
Hi Sudhanshu - I see couple of problems with the current model.
1) Mass/Inertia for all the bodies are zero. You need to fix it.
2) Graphic h3d cannot be used as a flex body. You need to generate a flexbody h3d via Flexprep tool.
regards
praful
regards
praful
Thanks Praful for your reply.
How to convert flexbody h3d via flexprep tool ? As I don't have .fem file , All I have is the cad part file as a Input which I have imported as a Geometry in Motion View.
