Dmoreau
.tcl script to create videos from multiple simulations
I have a script to generate multiple .avi videos from multiple LS-Dyna simulations.  In Hyperworks (version 14), I used to be able to just solely script the "capture animation" command in order to generate the videos. However, I now have to press "start/pause animation" in order to load the d3plot files into the simulation before being able to capture the animation.  If I do not do this, the program hangs and I am unable to generate a video.  I have found a temporary workaround by disabling one of the graphics cards on my computer to run the script, but I was wondering if anyone else had been able to find something to fix this issue.  The current script I am using is here which does NOT work without my workaround (which I would prefer not to use).  Does anyone know how to fix my script to generate these videos without disabling the graphics card?  We believe that a Windows update has changed something in order to make the old script not work.  I have pasted the old script in red and the new script is underneath that.
*OLD*
hwi GetSessionHandle session
session LoadSessionFile front.mvw
session GetAVIExportOptionsHandle myAviOptions
myAviOptions SetFrameRate 10
session CaptureAnimation avi front.avi
session LoadSessionFile side.mvw
session CaptureAnimation avi side.avi
session LoadSessionFile side_section.mvw
session CaptureAnimation avi side_section.avi
session LoadSessionFile side_section_outboard.mvw
session CaptureAnimation avi side_section_outboard.avi
*NEW*
session GetProjectHandle project
project GetPageHandle page 1
page GetAnimatorHandle animation
page GetWindowHandle window 1
page StartAnimation
session Close
Livil,
I added that command into the script, but the capture animation still hangs in the middle.  I will add a few pictures to this post to show what I mean:
After running in powershell, the script hangs here at the capturing phase:
Inside Hyperworks, it looks like this in the bottom left corner.  The bar stops and will not continue forward:
If I hit play before hand, it shows this in the bottom left corner before going to recording animation:
And the animation will record.  So far, anything I have tried to script will not "play" the animation before capturing it (see above script and your comment).
Any other ideas?
