Sign in to follow this
defining motion
when I define a motion for a link at a specific location in a rigid body it runs without problems. However, when I add two joints between 3 rigid bodies and use the same motion file for each revolutary joint, job keeps failing. The first joint which works on its own is grounded and the second one is between two RBs. I am not clear why this is happening
thanks for the help in advance
mert
