Sign in to follow this
Eroded elements ?
Is it possible to turn off eroded (eliminated) elements ("off" in Hyperview) in the hyperview player ?
Mario
Hi Mario
I've had the same problem with eroded elements still being displayed when I try to generate an H3D animation from HyperView 8.0SR1 on my Windows PC. It doesnt' change regardless of the Tools, Options, Visualization Display setting of "Display eroded elements" or with a compressed or uncompressed version of the H3D file. However, old H3D files generated in version 7.0 do display properly, so my workaround is to post-process using version 7.
Eric
Hi Guys,
The option for turning on/off the eroded elements is available in the latest version of HVP, i.e, HVP9.0.
Sunil
Yes in HVP9.0 the option of turning on/off eroded elements is available under the Display Options.
Thank you,
Liz
There is an option to turn on/off eroded elements in HVP9.0 but it doesn't seem to change the display. The eroded elements remain displayed. Is this an error when the H3D file is generated from HyperView9?
I can load an earlier H3D file generated in HV7 with eroded elements and it will correctly toggle on and off in HVP9.0.
Unfortunately I can no longer use HV7.0 to generate H3D files due to changes in our license.
Eric
