puneet.shahare
*** ERROR 14: Missing element ...
Solver- optistruct
I am getting the error 14 for every contact surface. It says - *** ERROR 14: Missing  element #7008278 referenced by    SURF # 30.
I have tried creating the contact surfaces again on these elements, but the problem persists.
There are overall 25260 such elements ( basically all the elements attached to the contacts surfaces).
does anyone here has the solution for this?
error msg
 *** ERROR 14: Missing  element #7007965 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007963 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007961 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007959 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007957 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007955 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007953 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007951 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007879 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007843 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007746 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007748 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007749 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007751 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007753 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007755 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007757 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007758 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007760 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007761 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007861 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007897 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007969 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008281 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008423 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008422 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008453 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7004997 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7004995 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7004993 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7004991 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008447 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008416 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008414 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008412 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008410 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008408 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008406 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008404 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008435 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7004979 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7004981 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7004983 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7004985 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006380 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006382 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006418 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006420 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006422 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006530 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006532 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006534 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006536 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006538 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006713 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006817 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006816 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006815 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006814 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006813 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006811 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006809 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006807 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006805 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006803 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006801 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006899 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007043 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007045 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007047 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007049 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007260 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007262 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007264 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007266 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007268 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007270 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007272 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007274 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007346 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007382 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007380 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007378 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007376 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007474 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007472 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007470 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007372 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007370 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007368 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007466 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007464 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007462 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007461 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007362 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007326 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007328 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007330 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007568 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007364 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007366 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007468 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007374 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007476 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007478 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007480 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007063 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007344 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007061 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007059 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007342 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007057 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007340 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007055 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007338 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007053 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007336 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007334 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007332 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007051 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007258 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007256 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007254 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006693 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006518 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006410 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006412 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006414 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006522 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006524 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006520 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006901 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006695 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006903 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006697 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006905 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006699 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006907 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006701 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006909 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006703 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006911 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006913 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006915 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006917 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006919 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006430 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006394 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006711 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006428 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006709 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006426 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006707 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006705 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006424 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006528 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006526 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006384 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006416 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7004987 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006378 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006376 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006374 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008263 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008437 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008439 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008441 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008443 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008418 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008445 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7004989 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006386 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006388 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008449 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006390 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7006392 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7004999 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008451 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7008455 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007895 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007588 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007859 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007586 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007857 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007584 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007855 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007582 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007853 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007580 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007851 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007578 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007849 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007576 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007847 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007574 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007572 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007745 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007570 referenced by    SURF # 30.
 *** ERROR 14: Missing  element #7007845 referenced by    SURF # 30.
 *** Errors with missing, incorrect or duplicate IDs found 25260 times.
error log.xlsx
@Rahul R
However, I could find the elements (e.g. element #7008278) using the Find element tool. I also tried to delete the contact surfaces and apply loads directly,
 now I am get the error that  ERROR 14: Missing  element #----referenced by    PLOAD4 # 2.
