bouvy
Batch Script Error
I am trying to run a batch script from the FEKO terminal. When doing so, I get the following error, and my job does not run:
Quote
Error connecting to the Service
[mpiexec@vem-2] ..\hydra\utils\sock\sock.c (270): unable to connect from "vem-2" to "VEM-2" (No error)
Where "vem-2" is the name of my PC.
I have attached text files of both the job script and the complete output from the FEKO terminal. Any help is appreciated!
Thanks,
Alex
job_script.txt job_script_response.txt
Hi bouvy,
I assume that all 40 cores are on the same machine? If so, add the following to the end of the runfeko command:
--parallel-authenticate localonly
bouvy likes this
