mimarcoe
How to mesh between two surfaces
I am trying to mesh a model that is a cube into another cube. I want to mesh the volume between the two of them with tetras, but i cannot.  I am using volume tetra, with enclosed volume: surfs. I only can select one of the two surfaces. Could you help me?
Thank you very much for your help.
Thank you for your help raviteja, my model is not symmetric, the internal surfaces is an offset of the external surface
I create a surface with the ruled option that connects the two volumes, but when i mesh with tretramesh (volume tetra with enclosed volume: surfaces). The program start the mesh, but then it says "Volume analysis failed". Do you know what happens?
Thank you very much
