Sign in to follow this
pmcardle
Half Planar Green's Function
  I am using a half planar greens function and am receiving this error for certain frequencies
 WARNING  3489: Too many integration intervals are required for the potentials
    See also message in the output file PEC_10.out
Is there a way to check the reliability of the solution? Is the solution at all valid?
Hi Pmcardle
Quite likely this is at the higher frequencies.
You could say compute the near field at one or two points vs frequency and check for a consistent trend in the curve. For example if you get a straight line but where the warnings appear suddenly noise, then you can't trust the results.
 Thanks, for the reply. As a follow up, does this error occur because the model is to electrically large? Or does it also depend on the effective wavelength in the half plane?
