Hi All,
I facing Issue in three widgets
1) Change the font of Inputs Dialogue in TK (e.g CAMBRIA , 14)
2) How to assign the values of a dynamically created Entry Box to a list using TCL.
3) How to assign the procedure to the buttons in Dialogue. (OK , APPLY and CANCEL on the dialogue Box situated at the bottom)
please help me to clarify these doubts.
Best Regards,
Dhairyasheel Desai
Hi Dhairyasheel,
1. first create a font with the properties and then assign it to the label you create
font create myFont -family cambria -size 14
ttk::label .test.frame1.label1 -text "Hello" -font myFont -width 15
2. all entry boxes have a variable set using -textvariable which should be a namespace variable, this can be set dynamically and will be reflected accordingly.
hwtk::entry frame_1.ent_1 -textvariable ::mynamespace::entry1variable
3. use -command followed by the function while creating the button:
hwtk::button frame_1.button_1 -text "test" -command {::test::Myprocedure}
Dhairyasheel likes this
On 12/20/2018 at 7:28 PM, Jeffersondhv said:
Hi Livil,
Thanks for the Reply. It was very Helpful. :)
1 ) My question was about font of INPUT DIALOG
"set myanswer [hwtk::inputdialog -title "Material" -text "Enter Material Name" -font myFont".
2) About Assigning the Procedure to the Default Buttons on the Dialogue Box (OK , CANCEL, APPLY) Please refer to the Images attached.
Thanks in Advance
Best Regards,
Dhairyasheel
Tata Technologies
