Sign in to follow this
Haj Hassan
Simulation not finished
Hi Haj
Your model was suitable for internal testing.
Attached a FEM/MoM version which I was referring to above.
It would seem that convergence is quite tough for this model. Using here a direct solution. It is more memory hungry, but from your OUT file I see you have enough memory for this.
The patch array feeds were converted to current sources inside the FEM region.
I have removed the mesh to reduce the attachment size. You would have to rerun the model your side and add the output requests which I removed for testing purposes.
You will need Feko version 2019 and run the updater to get version 2019.1
Lens_FEM_MoM_direct.zip
