Sign in to follow this
Marcus Chang
warning message in FEKO
Dear all,
Recently, I try to use a near field data as the source, and try to get it's far field results.
However, it shows a warning message as below:
WARNING 3411: No accurate power calculation possible if two non-orthogonal elementary dipoles of the same type are at the same position
Received message from server process 2:
WARNING 2407: Computation of the near field of a Hertzian dipole not possible at the dipole location
Could you help us check what does it exactly mean in this case?
Is there any solution to solve it?
BR/Marcus
validate NFsource radiate direction.cfx campactrange_PlaneWavesource_cornerreflector_190827_Ray_01_NearField.efe campactrange_PlaneWavesource_cornerreflector_190827_Ray_01_NearField.hfe campactrange_PlaneWavesource_metallicsphere_190827_NearField.efe campactrange_PlaneWavesource_metallicsphere_190827_NearField.hfe
Hi Mel,
After I upgrade Feko to version 2019, and try to solve the same problem, another similar warning show up again as below, please check:
The following message from the master process (MYID= 0):
WARNING 53119: Possibly inaccurate active power (far field gain) when using equivalent sources in a coupled environment
is there any suggested solution to solve it?
BR/Marcus
The E-fields will be correct. The gain could be wrong since the source power (upon which the gain is based) cannot be accurately determined.
There is no way around this.
