1 hour ago, Geraldo Osorio said:
Hi
Could you help to understand more details, behind online help, about parameters below?
Do I need specific lincense for these parameters?
Thanks.
Hi Geraldo,
FASTFR : This option is used to activate "The faster modal solution method" for modal frequency response analysis !
FFRS : The second means FAST Frequency Response Solver, used if you want to activate the external FASTFRS solver. This solver works well for a large modal frequency response. (You have to install it in advance).
FFRSNCPU : used with FFRS. It's useful if you want to define the number of CPUs to be used by the external solver "FAST Frequency Response Solver".
FFRSLFREQ : It's a threshold (cut-off frequency) used to partition your system into low freq and high freq.
Cheers,
Geraldo Osorio likes this
On 9/18/2019 at 12:46 PM, Geraldo Osorio said:
Hi Farouk
Do you know any external solver "FAST Frequency Response Solver"?
Thanks
Hi Geraldo,
I joined a paper in which we explain some Fast FRS development.
Cheers,
Kim_et_al-2007-International_Journal_for_Numerical_Methods_in_Engineering.pdf
