Sign in to follow this
tehran
calculate torque
Question N°1 about max torque :
When you draw the curve of the torque (function of time for example). Right clikc on the curve, select edit. you will get the mean, min,max…. values of the toruqe
Question N2 about iron lass using Preisach model :
You need to follow the steps :
  • Create sensor befor solving. The type of sensor : integral (on face or volume , it depend on your Flux project)
  • Select type of support (face of faces region for example). You select the face on whisch you use the Preisach model
  • For the spatial formula, select : dpower/dv
When you draw you curve after solving, you need to start form step 3
Best regards.
