Sign in to follow this
I'm working in MotionView for the very first time, so I apologize if my problem may seem trivial.
I've imported a geometry in motionview from a step file and consequently bodies have been created.
How can I define points in order to, in a second step, specify joints? Some tutorials show that points can be created using a point table file, but how can I create this table? Is there a method to create it from my step file? Or is there another method to create points directly in MotionView?
hope to receive some explanations. Thanks in advance.
Hello Francesca,
From a table you can use this option and open a .csv or .txt file.
From the Step you can enable CAD feature recognition under Tool--> Option --> Build Model and select points or directly joints using the CAD features.
Best regards,
Felipe.
