Tim
Host ID without Ethernet Adapter
Hi, i have trouble finding the Host ID because my Laptop does not have a Ethernet Adapter
which Physical adress should i use instead?
IP Config File:
C:\Users\Tim>ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : DESKTOP-*******
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : fritz.box
Wireless LAN adapter LAN-Verbindung* 1:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physical Address. . . . . . . . . : 40-A3-CC-29-19-0A
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter LAN-Verbindung* 3:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
   Physical Address. . . . . . . . . : 42-A3-CC-29-19-09
Wireless LAN adapter WLAN:
   Connection-specific DNS Suffix  . : fritz.box
   Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 8265
   Physical Address. . . . . . . . . : 40-A3-CC-29-19-09
   Link-local IPv6 Address . . . . . : **********
   IPv4 Address. . . . . . . . . . . : ***********
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Tuesday, September 24, 2019 10:57:12 AM
   Lease Expires . . . . . . . . . . : Friday, October 4, 2019 4:48:23 PM
   Default Gateway . . . . . . . . . : ************
   DHCP Server . . . . . . . . . . . : ************
   DHCPv6 IAID . . . . . . . . . . . : ************
   DHCPv6 Client DUID. . . . . . . . : *************
   DNS Servers . . . . . . . . . . . : ***************
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth-Netzwerkverbindung:
   Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
   Physical Address. . . . . . . . . : 40-A3-CC-29-19-0D
Thanks in advance
