Junta
Calculation of Pressure rise
Hello expert,
  • I have a question about the expression to use when i want to calculate the PRESSURE-RISE in a system which has a pump/fan inside.
As i have gone through tutorial Acu-T 5000: Blower - Steady, it shown that how to calculate pressure rise by:
 PRESSURE_RISE = PRESSURE_outlet - PRESSURE_inlet. (this is STATIC PRESSURE value)
  • But follow my understanding with Bernoulli's law, the expression should be:
   PRESSURE_RISE = Total_Pressure_outlet - Total_Pressure_inlet
Can anyone help me clear this thing? Also correct if i am wrong.
Appreciate any help.
Thanks in advance.
The equation given in the tutorial compares static pressure.  If you want to compare total pressure, then your expression would be correct.  It depends on what you want to compare - static or total.
Junta likes this
hi acupro,
thanks for your answer.
do you know normally what kind of pressure rise is used when evaluating a pump? static or total?
My guess would be that static pressure would be typical, as that is simpler to measure, and doesn't obstruct the flow.  Simply drill a hole in the side of the inlet and outlet pipes and put a tube there - flush to the inner/wetted surface.  A total pressure measurement requires a pitot probe - where you install a device that protrudes into the flow and bends such that it points directly into the oncoming flow.  I assume there's no harm in reporting both, but I would guess static pressure rise is typically reported.
Junta likes this
hi Acupro,
Thank you very much.
Your explanation help me clearly understand about this.
Thanks again.
