Sign in to follow this
Viking_d
STL mesh file export from Hypermesh
Hello ,
I have been trying to export a mesh file from Hypermesh as an stl file. I want the normals oriented in a certain way .
Does exporting as .stl file from Hypermesh change the orientation of the Geometry? I have been constantly getting errors with the geometry orientation.
Of course, when you change the normal direction of your mesh within Hypermesh, the STL output will be changed.
Have a look at output in the following:
facet normal  0.0           0.0           1.0
    outer loop
       vertex  0.000000E+00 5.0000000E+01  0.000000E+00
       vertex  0.000000E+00 3.3333333E+01  0.000000E+00
       vertex 1.6666667E+01 5.0000000E+01  0.000000E+00
    endloop
endfacet
and when I changed the normal, output will be:
facet normal  0.0           0.0           -1.0
    outer loop
       vertex 3.3437438E+01 2.0355164E+01  0.000000E+00
       vertex 5.0000000E+01 1.6666667E+01  0.000000E+00
       vertex 3.3333333E+01  0.000000E+00  0.000000E+00
    endloop
endfacet
Yes, I understand that. When I view the normals on Hypermesh the orientation is correct, the way i want it.
But when I export it as an STL file, and view the geometry in another tool the orientation of a few elements seem to have changed.
So I am assuming there is a problem with the export as STL option?
