Sign in to follow this
Ushay
Error: Can't read "vx1": no such variable
Hello all,
In a part of my script the vector coordinates are pulled for a later use. When I execute I have the following error message
Error:
can't read "vx1": no such variable
    while executing "*createvector 1 $vx1 $vy1 $vz1"
Code:
        *vectorcreate_twonode $x $y
        set vectorList [ hm_getmark vectors 1 ];
        foreach vct $vectorList {
            set vx1 [ hm_getentityvalue vectors $vct "xcomp" 0 ]
            set vy1 [ hm_getentityvalue vectors $vct "ycomp" 0 ]
            set vz1 [ hm_getentityvalue vectors $vct "zcomp" 0 ]
            return "{ $vx1 } { $vy1 } { $vz1 }"
        *createmark nodes 1 $x
        *duplicatemark nodes 1 25
        set r [hm_entitymaxid nodes 1]
        *translatemark nodes 1 1 10
Would be great if someone could tell how to reference the coordinates vx1, vy1 and vz1 in the other parts of the code.
Thanks in advance
You have a list of vectors but you want to translate it into one direction. The problem is that the variables are only valid within the for loop...
try this
set vector [*vectorcreate_twonode 1 2]
set vx1 [ hm_getentityvalue vectors $vector "xcomp" 0 ]
set vy1 [ hm_getentityvalue vectors $vector "ycomp" 0 ]
set vz1 [ hm_getentityvalue vectors $vector "zcomp" 0 ]
*createmark nodes 1 1
I changed the $x and $y that it works for me... also the createmark command after that...
Hope this helps
llyle likes this
