Dear users,
I am running a modal analysis in Optistruct for a simple 2D plate in order to validate some Matlab scripts.
I use CQUAD4 elements (PSHELL 2D property) in HM.
Results from OS are consistent if I compare them with a 6-DOF per node element in Matlab.
Now, I would like to compare the same case for membrane elements (2-DOF per node) but I am not able to find a way to model a membrane in HM.
Any suggestion about a different element?
Thank you
Regards
Fabio
Quote
for Optistruct the following behavior are valid:
- To model a membrane plate, use only MID1
- To model a plate with bending stiffness only, use only MID2
- For bending with transverse shear flexibility, use MID2 and MID3
- Use MID3 to include an extra shear term in the element stiffness calculations (i.e. includes transverse shear flexibility).
- For a solid homogeneous plate, MID1, MID2, and MID3 should reference the same material ID
- MID4: The MID4 field (bending and membrane deformation coupling) should be defined only if the element’s cross section is unsymmetric. Default is blank = symmetric cross section.
(Note: Mass is not calculated if MID1 is blank.)
In summary, the results of leaving an MID field blank are:
●MID1: No membrane or coupling stiffness or Mass
●MID2: No bending, coupling, or transverse shear stiffness
●MID3: No transverse shear flexibility
●MID4: No bending-membrane coupling
The standard for typical shells (thickness about 1/15 of size) is to use the same ID for MID1, MID2 and MID3.
To define a membrane, please leave MID2 and MID3 blank on the PSHELL property, or use PARAM,SHL2MEM.
